proe machining
proe machining
proe machining
In proNC I used to get 3D solids (assemblies) for my cutting tools. In that case I'm supposed to be capable to preview BOMs for those tools in Tool_Window, tab "BOM". Actually I can do that but all the components of my tool are of type "GENERAL" (you can see it in the column "type").
What parameter should I introduce in 3D solids to reflect its type (cutter ar holder) in proNC correctly?
Thanks in advance
