"Dot" symbol for Derivative
Does any one know if it is possible to get a “Dot” symbol over a variable for a derivative????   If it is possible, how do you do it?  I am using MathCAD 2001.
Jeff
RE: "Dot" symbol for Derivative
Hi stephens248,
I'm afraid that I don't think it's possible.  While Mathcad does allow you to alter the display of the derivative from normal-looking d's to lazy-d's (regular derivative vs. partial derivative) it won't let you assign a dot to the derivative.
Think about it -- the current derivative operator requires you tell Mathcad what variable to differentiate with respect to.....so if you only used a dot how would Mathcad know which variable to use?
If you're just trying to write out an equation to insert into a presentation or other document, the Microsoft Word equation editor should do the trick.  I know you can insert single, double, and triple dots above expressions to indicate derivatives.  (But Word just displays it....no evaluation possible there.)
I have Mathcad 2001.  If anyone else finds anything to the contrary let me know. :)
Hope that helps,
Matt
Well it was part of a report, but I was using it more or less as a variable.  I did not think about MathCAD not knowing what to differiceniate with respect to by using the dot.  Oh well, no big deal.  Thanks for the response though.
