How do you remove a label from a baked bean tin?
I have been asked to quote for an automatic machine to remove the labels off food tins ready for re-labeling. This done when tins arrive in this country with incorrect language or errors on the label.
Does anyone know how labels can be cut consistantly without damaging the tin or contents and without human intervention? Once the label has been cut from top to bottom I will be OK.
Many thanks
John
bespokemachimes.co.uk
Many thanks
John
RE: How do you remove a label from a baked bean tin?
Fast drying.
Not enough heat to spoil anything.
Fast, clean.
Sounds good for food...
Compressed air knife.
Water jet to slice.
