Multiple veiwport problems
I have not drawn using autocad for a while so I am sure it is because my brain shut down
When I have created my 2-d drawings in layout space using solveiw, My veiws do not display the hidden lines as hidden after I perform the soldraw command. (I have the hidden line type loaded before I do this.) WHen I click on one of the lines that should be displayed as hidden, it says it is. When I print the drawing it comes out with the dashed hidden line.
Also the dimensions will at times not display in the 2d veiws until I print it or veiw it in the print preveiw.
As if this is not iritating enough. When I try to regen or redraw a drawing so that circles do not look like polygones or squares....not a thing happens. The cicles still look like crap.
Someone please tell me what I am doing wrong. IS my machine an oil leaking dogsled? The last Time I worked with autocad 2002 was on another machine at another company about a year and a half ago and I did not have these problems.
Dave
Dave
RE: Multiple veiwport problems
Not a 3D user but have seen these mentioned before.
I had a similar problem with disappearing dimensions in Inventor.
Thanks for the help. I wish I would have found this site sooner
Dave
