installing SW 2004
installing SW 2004
Should I leave 2003 on my machine or delete it prior to installing 2004?
Bob Snead
Lead Designer
Northropgrumman.com
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: installing SW 2004
ctopher
Sr. Mech. Designer
I have SW01+, SW03 and SW04 all one machine and everything is great. You just have to pay attention to what your doing when installing and make a new installation each time and DON'T USE UPGRADE do an new installation and everything will be fine. I can't stress that enough.
SW needs to remove the upgrade option from that menu. I have yet to see that work correctly yet.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
Why wouldn't you delete the old versions? Would it hurt to do so? just curious
thanks
Bob Snead
Lead Designer
Northropgrumman.com
Bob Snead
Lead Designer
Northropgrumman.com
No it wouldn't hurt to delete it, but if you haven't ran SW04 and fully tested to make sure it works well for you and your with your products. It might benefical to keep SW03 on your system just in case you would need to backtrack back to SW03. Keep in mind you can't send SW04 files back to 03 still. That's why you need to fully test it before it's used in production.
Scott Baugh, CSWP
FAQ731-376
That's a good question. I reformatted an old NT system and had to do a fresh install of SW 2003. Photoworks will no longer work (posted this in another thread). Is this any different with SW 2004? If not, how shall this be handled?
Jeff Mowry
DesignHaus Industrial Design
http://www.designhaus-i-d.com
So you have the new disks - PhotoWorks is on every set of SW disks.
You have to tell it you want that program and it will ask you for the original (98?) disk serial number (just like SW), but it will install fine. I think it may have varied a little. Sometimes I seem to recall it comes up with the choice first, others it waits till after SW installs. You need to tells it to install other options, or something - it's there somewhere. If I get round to installng 2004 at home this weekend I will be more specific next week.
Now if you load SW 2004 you have to have PhotoWorks 2 which again is on the disk with SW. The old stuff will not work.
3/4 of all the Spam produced goes to Hawaii - shame that's not true of SPAM also.......
HKEY_Current_User\Software\Solidworks
(there is no folder here)
I do however have:
HKEY_Local_Machine\Software\Solidworks
HKEY_Local_Machine\Software\Solidworks Corporation
Is XP pro different from OS that is described in the FAQ section? Does XP pro handle this differently?
Thanks in advance
mwall
There is a note in the FAQ "If some of those reg settings are not there, it's ok the Uninstall took them out. Continue on."
That means just like it sounds.
Scott Baugh, CSWP
FAQ731-376
Just reinstall the toolbox back in the same folder as it was before.
Scott Baugh, CSWP
FAQ731-376
You are talking about reinstalling toolbox from 2004 correct?
If we reinstall toolbox in the same folder as before will we lose all of our configurations?
We tried a new install and pointed SW 2004 to the location of the old toolbox. We got an error saying that SW 2004 was not compatible with the old toolbox.
Derek
John Richards Sr. Mech. Engr.
Rockwell Collins Flight Dynamics
A hobbit's lifestyle sounds rather pleasant...... it's the hairy feet that turn me off.
