EPS file from SW Drawing
Does anyone know a way to produce Encapsulated PostScript (EPS) files from SolidWorks drawings?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: EPS file from SW Drawing
Other options:
In the past, I have PS-based hijacked printer drivers to produce PS and EPS. Basically, install the printer driver so that it defaults to print to a file.
PDF is PS based. Save or print to a PDF and open in Adobe Illustrator or Corel.
Hijaak Pro is an amazing reading and concersion tool. Usually available for less than US$200.
You need to set up a PostScript printer somehow. This may be difficult if you do not actually have a PostScript printer.
Once you have a PostScript printer, you print to file.
GhostScript is a PostScript interpreter. It is very helpful once you have a PostScript file to play with. It will convert PostScript into whatever it is your printer understands, even if you have a nine pin dot matrix!
GhostSctript also creates TIFF, JPEG and PDF files from the PostScript.
GhostScript converts FROM PostScript, not TO PostScript, so it will not help you with SolidWorks.
JHG
I used to find print drivers available at printer manufacturer websites ready for download. Also, your Windows OS may have some default drivers handy. Once you have a driver, just go through the Windows routine to install a new printer, and direct that printer to print to a file instead of a port.
Why do you need an EPS? Maybe there's a better way.
What are you ultimately trying to achieve?
Give us a 10,000 ft view and let's see if there is a better way to get your END result.
3/4 of all the Spam produced goes to Hawaii - shame that's not true of SPAM also.......
DXF can be brought into Illustrator, as well, but there can be some difficulty.
Again, having a seat of Hijaak around can do wonders for your interoperability scenario.
I did several google searches and found this web page that had step by step instructions and a link to the adobe PS printerdriver...
Here is a Site… ( http://www.synergy.com/exporteps.htm )
Windows instructions:
These steps are for Windows 95 and 98. Under Windows NT and 2000, an Adobe PostScript printer driver must be selected in the Print dialog. Other drivers may not allow you to select EPS for the Output Format. To download a driver go to: http://www.adobe.com/support/downloads/p...
1. Choose File > Print (Print Graphics in KaleidaGraph).
2. Select the Print to File check box.
3. Choose a PostScript driver and click Properties.
4. Click the PostScript tab and choose EPS for the Output Format.
5. Change the file extension to .EPS (often defaults to .PRN).
6. Click OK until the Save dialog is displayed. Once you enter a file name, an EPS file is created on your hard disk that can be imported into another program. You cannot preview the image in the destination program, but it will print correctly.
