pressure transducer
pressure transducer
pressure transducer
hi all,
looking for a pressure transducer to be installed in an extruder machine. i want to fit it into the barrel to see what pressure is being generated.
maximum pressure is 250bar
maximun temperature is 230 deg oC
must be a 3 wire either 4-20mA or 0-10v output
sizes 1/4 " or 1/2" thread
any help is most welcome on finding a suitable part
thanks
lesliemcg
RE: pressure transducer
Leslie,
    I would take a look at "Efector" brand. You probably have to order a custon sensor from them if you want to operate at 230 celsius.
Afterhrs
Dynisco makes sensors specifically for melt pressure sensing.  I would look at their catalog.  From what you say you are interested in, I believe something should be standard.
Try looking at PT46xx series (pg78 in 5th edition catalog)
This is what we use.
Adam
MPI Melt Pressure offers a very good economical pressure transmitter.
Check out the MT204 series.
Only costs around $480
www.mpipressure.com
Check www.globalspec.com in and in its transducers and sensors devision. then go through choosing your sensor, step by step. It's a huge database. I hope it would help.
Cheers
You can live in your car, but you can't drive your House!
