Searching for Claus Unit experts
does anybody have an experience with installation of relief valve on the Acid Gas Preheater (in front of the second Claus reactor)? I would like to know if you find necessary to install it.
Thank you,
Jana
RE: Searching for Claus Unit experts
I would contact Porocel Corporation.  They have experts in this field.  I am sure they would be glad to talk to you.
Mike Sharp
281-920-3338
Ed Luinstra
403-686-1562
www.porocel.com
For your question I am not sure Porocel catalyst people are the best to contact.  Typically, there are no relef valves in a Claus plant on the sulfur processing side as they would get plugged off.  It is also unlikely that there is a relief valve on the heating side.  Process equipment is usually designed for 50 psig but not registered since processing is below 15 psig.
Thank you for your reply.
I am searching for opinions. I normally do not design relief valves in Claus reheaters. But last time I had a customer who insisted on their instalation. That made me curious.
