Tank Inspection compliance
The company I work for has several tanks that have not been removed from service for internal inspection for between 12-15 years. The last unit inspector falsified records leading the company to believe that all tanks were compliant. My question is, is there anything we can do to get compliant without removing tanks from service? Like submerged UT etc. Because of the number of tanks it will take 2-3 years to be able to remove each tank from service for inspection. Any / all suggestions will be helpful.
RE: Tank Inspection compliance
a plan of attack is at least a start.
