Multiple Drawings using MS Access as a database
I need to blast MS Access97 field text into multiple wiring diagrams drawings using a template drawing and a Lisp routine. The graphics in these drawings is identical except for "TEXT" (Motor name, number,location, plc address, etc). Is there a publication that details this procedure better than the Autodesk Users guide. Anyone?
RE: Multiple Drawings using MS Access as a database
I created a file named insert_text_two.dwg (note it is best to avoid using spaces)
The file has everything drawn out plus I have two parts of text that can be changed.
To make text that can be changed goto:
Draw/bloocks/Define attributes
Put in a tag (I recomend using your your access column names)
Put in a prompt (use the same as the tag name)
leave value blank
Pick or specify insertion point
Specify text options as per your preference
save file (make sure directory path has no spaces)
now your on the access side of things
make access create a text file with the following thing
'do not put in parts after the' mark
-insert 'just an enter after insert no spaces
u:\insert_text_two.dwg 'or whatever path and file name
0,0,0 'specifies origon as reference point
1 'scale factor
0 'angle
text for each value here 'note spaces aren't a good idea
' if they are unavoidable you
' might ba able to do something
' with quotes or using a lisp
' routine(I use autocad light so
' lisps are out of the question"
The file needs to be saved with the extension .scr
when you open autocad from access
you wil do something like this
stBatch = " /b S:\cd-eng\access.scr"
QUOTE = """"
stAppName = "P:\AutoCadLT_2000\aclt.exe"
stFileName = Me.Path & "\" & Me.File_Name
Call Shell(stAppName & " " & QUOTE & stFileName & QUOTE & stBatch, 1)
anyhow this should get you started.
Tim
Command: -insert
Enter block name or [?]: u:\insert_text_two.dwg
Specify insertion point or [Scale/X/Y/Z/Rotate/PScale/PX/PY/PZ/PRotate]: 0,0,0
Enter X scale factor, specify opposite corner, or [Corner/XYZ] <1>: 1
Enter Y scale factor <use X scale factor>: 1
Specify rotation angle <0>: 0
Enter attribute values
Name: My Name Here
Date: My Date Here
