Where is the deck longitudinal joint come from?
Can someone tell me where is the deck longitudinal joint came from? AASHTO?
Per IDOT bridge manual, we need to place deck longitudinal joint if deck width over 90 feet. But where is it come from and what is the purpose?
Thank you.
Thank you.
RE: Where is the deck longitudinal joint come from?
DOTs usually have a preference based upon previous performance of bridges already in service.
The idea here seems to be to limits effects in the transverse direction. Think about it: If you had a bridge LENGTH of 100 feet, would you not expect significant movement at the ends? Limiting the width serves to keep the line girder assumptions valid, and keeps bearing design and detailing simple.
I suggest using a deck-supported neoprene box seal gland in a steel extrusion for a longitudinal joint, but watch your end conditions! They can be troublesome.
Curvbridger
