Config file errors
Config file errors
When I open a part I get this error message...
"1 error found in config file. Do you want to apply?"
If I click yes it seemes to open the file fine. It alsoo writes a cfgerror.txt file containing the following...
"Line 5: Unknown keyword NOTES."
I've searched my config files and haven't been able to find the word NOTES anywhere.
Does anyone have any idea what this might be?
Thanx
Thanx
RE: Config file errors
It will read the one in the startup (bin) directory if there is one.
Using NT and creating a shortcut to the desktop will allow you to read one in a working directory.
One more thing...
If you load the config after you start a model or dwg does it give the same error?
Also what release are you running?
procadman2
Proe Design & Admin
NASA Contractor
"You can't build a reputation on something you haven't done."
H Ford
I only have 1 config.pro file in the starting directory.
When I open and apply the desired config.pro file I get no errors.
I'm running 2001 with Windows 2000.
Did you reinstall ProE recently? I had to and install an older version of ProE by mistake, and I had a similar issue. To fix it just get the latest version of ProE that you have and install.
Tofflemire
I had been working from home using a VPN connection (thus using my same FlexLM server) and the files I started from home didn't seem to have the problem. When I started using files from the office, the problem seemed to spread to the files I had originally started at home.
Sounds pretty virus-like.
I will try the re-install and see where that gets me.
