Table Driven Parts
Table Driven Parts
I just started using table driven parts for similar parts (ie same part different lenghts, different features threaded or non threaded end etc...) for parts instead of creating one part and doing a "save as". When I insert these parts into an assembly Inventor creates a sub directory and then creates mutliple part files for each of the parts that are in the table. Why does it do this? Doesn't this defeat the purpose of having a table driven part? Can this be turned off?
RE: Table Driven Parts
see http://www.sdotson.com/tutorials.asp
for more info on iParts
Sean Dotson, PE
Inventor Tutorials & More
www.sdotson.com
Sean has some great Tutorials about Iparts and how to set-up the file structure.
