V5 cut & paste feature to new part
I am trying to cut and paste a feature created in Generative shape (loft)  but when I paste into a new part I get the following:  Update Diagnostics  - Invalid token input?     seems to be looking for ref. geometry??
Thanks in advance!
RE: V5 cut & paste feature to new part
hi,
do you have any axis in your part ? did you use that axis to create any link (for a sketch plane? for a sketch ref ?)
most of the time, using the axis is no good, use default ref plane or build some line if you need axis (line PT/dir)
Hope that will help
Eric N.
catiav5@softhome.net
I haven't created an axis,   part was imported from V4.
I have used the extract command on the surface to break the link back to the supporting wirefreame and points.
Thanks!
