Simple Wireless Vibration Monitoring?
Most of the condition monitoring systems on the market are highly sophisticated and very expensive. They involve high bandwidth and fast data transfer rates, which are not necessary in my particular application. I need a wireless transmitter/receiver unit that is very simple........only 2 bits of digital data sent when a predefined tolerance limit is exceeded. Any ideas would be helpful.
RE: Simple Wireless Vibration Monitoring?
<nbucska@pcperipherals.com>
I hope giving this information is OK
you use infrared ? Ultrasonics ?
Are the TX and Rx in one building ? could you use the line ?
How much error-rate can you afford ?
If you want help, give spec's !!!!
