Healing V4 model in V5 (model dimensions)
I have imported a V4 model in V5 and I am now trying to join the surfaces together to get a volume. I have done all the surface topology checks and smoothed the corrupt surfaces - But, now I get the following error during join command "Selected elements have not the same dimension"
Not sure what this means???
Any help would be greatly appreciated!!
RE: Healing V4 model in V5 (model dimensions)
This problem occurs when you try to JOIN surfaces and curves (or point) in the same JOIN feature.
=> CLEAN your selection
Eric N.
catiav5@softhome.net
