Sine wave generator
Sine wave generator
Help
I Need to produce a good quality variable sine wave of 20V
between 25kHz 150KHz can anyone help
Many thanks
Many thanks
RE: Sine wave generator
<nbucska@pcperipherals.com>
http://www.thomasregister.com
and type Generators: Signal
which will return 74 Companies to contact and choose from.
It's very easy to generate sine wave.
here are some examples for you:
you can use
VCO ICs (voltage control oscillators)
or some oscillator using FETs(Field Effect Transistors) such as piers oscillator etc...
another alternative is using function generator ICs
like XR2206 or MAX038 you can generate sine wave,triangle wave and square wave with these ICs.
another simple way to generate sine wave is using 555
IC timer to generate square wave and the using an integrator to change square wave form to something like sine wave but this method will not make a good shape sine wave but it's very simple
for newer oscillator ICs you can go to national semicondutor's web site and type your search word as "sine wave oscillator".
if you still can not make a sine wave generator you can contact me directly by this email address.
kasra_ravanbakhsh@hotmail.com
i'll help you to make that!!!
sin wave generator? go with jbartos hit the home pages of say national semiconductors or any of the major chip makers. They all make (well nearly all) voltage controlled oscillators (VCOs). They should have typical circuits, if there isn't anything on screen send them an e mail and they will gladly put technical data sheets your way.
I reckon for a couple of dollars you should be able to put to gether a nifty little cct.
Let us know how it goes
Don
