Boiling point of gasoline.
I was wondering if anyone could tell me where to find the boiling point of unleaded gasoline at different pressures? I am really interested in the boiling point of unleaded gasoline at 35 psi, but would also like to find a source for other pressures.
Thank you,
Joe
Thank you,
Joe
RE: Boiling point of gasoline.
Your question is not as simple as it would seem. The problem is that unleaded pump gasoline (or petrol if you prefer), is a combination of many different compounds, each with its own physical properties. The various oil companies have their own proprietary blends that vary from region to region and by season of the year.
A liquid is said to be boiling when its vapor pressure exceeds atmospheric pressure. That's why boiling temperatures increase with added pressure, and decrease when pressure is removed. The different hydrocarbon chains that may make up pump gasoline have boiling points ranging from as low as 10 degrees F, all the way up to over 600 degrees F. Without knowing the exact composition of the fuel, an accurate boiling point can not be predicted.
Bryan Carter
http://www.blackmer.com/myapp/pdf/bul50....
Unfortunately it does not go as high as you would like, only 20 psi. And, I think it's pretty old info, so don't rely too heavily on it
Thanks again for all your help.
