Low secondary burdens on HV CVTs
Would anyone happen to know if there have been any studies looking at the effect of placing small secondary burdens (less than 5 VA) on high voltage CVTs?
The main issue is whether or not CVT transient effects are aggrivated by having little burden on the output of the CVT tuning circuit. The utility I work for is undertaking an extensive work program that is replacing older electromechanical protections (fairly large burdens) with digital relays (extremely small burdens) and currently there is no plan to refurbish/retune the CVTs. Is this necessary?
Any help/advice would be appreciated.
RE: Low secondary burdens on HV CVTs
http://www.wattnode.com/products/current...
etc. for more info
If the CVT is rated <=10% at 100 VA after 1 cycle, then the performance at 10VA is going to be between 1-2% after 1 cycle.
Unless you have one of the older CVT designs that have adjustable ranges (i.e. one setting for 0-100 VA and one setting for 100-200 VA) then there should be no need for readjustment. The CCVT's accuracy is checked at zero and full burden per standard.
The other concern would be for internal ferroresonance suppression. Most CVTs with a passive suppression design have an internal stabilizing burden that is always connected across 1 seconday winding and then a second resistance that is switched in to help dampen out ferroresonance.
I don't see anything on the link you suggest that concerns CVTs...it looks like a link to 600 V CTs??
Voltage and current instrument transformers for low power may be called Low Power Instrument Transformers. Visit
http://198.173.130.4/Main/trench/trenchm...$FILE/E900.pdf
etc. for more info
Also, visit
http://www.hut.fi/Yksikot/SJT/Vk-2002.pd...
Section 3.4.6
The ratio and phase displacement were compared with nominal
burden of 1 VA at unity power factor.
Visit
http://www.thomasregister.com
and type Transformers: Instrument under Product or Service, which will return 115 companies to approach to
The hut reference is about impulse measuring equipment, which again is not the topic here.
Worldwide CCVT manufacturers are Ritz, Trench, Alstom, ABB, Arteche, Passoni Vila.
Visit
http://www.geindustrial.com/products/bro...
http://www.geindustrial.com/products/app...
for GE Bushing Voltage Transformers
There is a capacitance of the bushing involved
http://www.trench.de/_FramesPages/Instru...
http://www.trench.de/_FramesPages/Capaci...
