AutoCad Problem
AutoCad Problem
I got problems on my autocad14. I drawed picture what include lots of block. No there in picture are lots of secret rubbish blocks. How to get rid of that rubbish?
RE: AutoCad Problem
RE: AutoCad Problem
When i take all blocks into sight and star deleting, it delete too important design(blocks). When i try to fix that problematic block with block editor, it sometimes succeed, but always dissapear attributes and all block.
Help me!!
RE: AutoCad Problem
Help me!!
RE: AutoCad Problem
What Striker means is, type on the command line:
PURGE
enter.
This should really work.
RE: AutoCad Problem
In that file you have to get rid of circle. And rest of picture must stay of the same type.
I think that you cant solve it=)
RE: AutoCad Problem
RE: AutoCad Problem
I saw something very similar to this happen at my last company. Almost every drawing had a mysterious 'Unit Circle' block listed. No such block was being (deliberately) inserted. None of the other engineers and draftsmen seemed to be concerned - -'oh, that just shows up..'
It took a while to determine the cause. Whenever an *ellipse* is created in AutoCAD (14 at least -- - - dunno about 2000 or 2002), a 'unit circle' block is needed (and created if it isn't already in the file). BTW, exploding an ellipse doesn't do anything for getting rid of the darn 'unit circle' block.
Anyhow, it turned out that there were two small ellipses that had been used in the creation of the newest company logo, dumped into the ubiquitous title-block. So the darn thing was being spread like a virus!
I re-did the title-block, including the logo - - prettied it all up (and simplified several poorly created portions of the title-block) and got rid of the darn ellipses. Then I went on a 'hunting expedition', cleaning up literally hundreds of old drawings, getting rid of these annoying extraneous blocks. I told every draftsman and engineer what had happened, and how to prevent it from happening again.
So about a year ago, the company laid off nearly every engineer and draftsman. (Not to mention 20% of the main labor force.) Three months after this, the management realized they didn't have enough engineers left to do their projects. (ummm...what did they expect?!?)
So they 'promoted' several shop-workers, that had a little AutoCAD knowledge to 'engineers'. (Yes, I'm still steaming about that...)
And, of course, one of them has been using an old title block, that was buried away in an un-used folder for a couple of years.
Two months ago, I was told that they are all seeing this 'Unit Circle' block on every drawing again. And was asked to tell them how to solve it.
(Insert evil laughter here)
Anyhow, the point is - - look *very* carefully at some of the 'simple' blocks you use a lot of - - some of them may be 'contaminated'.
Curmudgeon
RE: AutoCad Problem
Remove everything you see.
Notice the difference between the two numbers when AutoCAD counts the entities. It should be significant.
____________________________________________________________
You can also try this one:
wblock
choose the drawing that you are in
<yes> replace it
at block name prompt enter: *
Now, open the same drawing without saving changes.
See if that works.
RE: AutoCad Problem
I enjoyed reading that story.
Funny I never noticed that unit circle for ellipses.
