Low class bituminous treatments in tropics
I am attempting to improve the buildable specifications for low class bituminous treatments in particular the islands of the Bahamas.  Generally a double surface treatment over sub-base/basecourse of crushed limestone is used.  RC250 cut back asphalt is used in the Bahamas.  I understand that RC250 is to be phased out for safety reasons - workers suffering burns.  What alternatives are there?  Any advice is greatly appreciated.
RE: Low class bituminous treatments in tropics
Emulsions can be used, but require longer cure times.
Consider using a mixed-in-place material using emulsified asphalt and the indigenous limerock in the Bahamas.  Only a light chip seal would be necessary to protect it and it would have more water resistance than the limerock base alone.
Other than that, you might consider a lower quality hot mix.
