Am Modulation
Am Modulation
Am Modulation
What is the modulation index and bandwidth of a normal AM signal? Also, if an AM wave is expressed as e=10[+0.6 sin(300 x t )]cos(2pi x10to the 6th)t volts where t is expressed in seconds. How do I determine frquency of the modulating signal, frequency of the carrier signal, and modulation index?
Skip
RE: Am Modulation
What is the problem you are trying to solve?
