304L /316L Welded in Salt Water Environment
I have been involved with manufacture of a subsea umbilical termination unit and the vendor has used 316L S.S and welded it to 304L S.S They should have only used 316L but decided off their own back to use the 304L. My question is will one be anodic in repect to the other? i know that 304L is prone to pitting in saltwater. should sacrificial C.P. be used?
RE: 304L /316L Welded in Salt Water Environment
FROM THE GALVANIC CHART BELOW YOU WILL NOTICE THAT 316 IS SLIGHTLY MORE NOBLE THAN 304. I WOULD ASSUME THAT THE LOW CARBON GRADE WOULD BEHAVE THE SAME.
COMPARE THE AREAS OF THE TWO METALS THE CORROSION RATE OF THE 304 IN THIS COMBINATION WOULD BE
R304_COMBINE = R304*(1 + AREA316/AREA304) WHERE R304 IS THE CORROSION RATE OF 304 IN SEA WATER
AREA316 IS THE EXPOSED ARE OF THE 316 SS
AREA IS THE EXPOSED AREA OF THE 304 SS
IF YOU DECIDE NOT TO USE CP MAKE SURE YOU PASSIVATE THE STAINLESS STEEL.
HOPE THIS HELPS,
RICH
GALVANIC SERIES OF COMMONLY USED METALS WHEN EXPOSED TO SEA WATER
ACTIVE OR    Magnesium
LEAST NOBLE    Magnesium Alloys
     Zinc
    Galvanized Steel
    Aluminum 1100
    Aluminum 6053
    Alcad
    Cadmium
    Aluminum 2024 (4.5 Cu, 1.5 Mg 0.6 Mn)
    Mild Steel
    Wrought Iron
    Cast Iron
    13% Chromium Stainless Steel
    Type 410 (Active)
    18-8 Stainless Steel
    Type 304 (Active)
    18-12-3 Stainless Steel
    Type 316 (Active)
    Lead-Tin Solders
    Lead
    Tin
    Maganese Bronze
    Naval Brass
    Nickel (Active)
    76 Ni - 16 Cr - 7 Fe Alloy (Active)
    60 Ni - 30 Mo - 6 Fe - 1 Mn
    Yellow Brass
    Admiralty Brass
    Aluminum Brass
    Red Brass
    Copper
    Silicon Bronze
    70:30 Cupro Nickel
    G-Bronze
    M-Bronze
    Silver Solder
    Nickel (Passive)
    76 Ni - 16 Cr - 7 Fe Alloy (Passive)
    67 Ni - 33 Cu Alloy (Monel)
    Type 410 (Passive)
    Titanium
    Type 304 (Passive)
    Type 316 (Passive)
    Silver
    Graphite
PASSIVE OR    Gold
MORE NOBLE    Platinum
There will be no measurable galvanic corrosion between these two alloys.  The problem is that the 304L will pit more readily - depends on temperature and available oxygen for reduction to support metal oxidation.  Once the pitting starts in the 304L it will be accelerated by the non-pitting 316 adding to the area available for oxygen reduction.  Cathodic protection is one way to prevent pitting.  Many coatings can also protect the stainless steel - immersion grade amine-cured epoxies or 100% solids epoxy novolacs should provide durable protection.
