Tap changing in 765 KV Power Transformers
Do tap changing is required in Power Transformers (generator and auto ) used in 765 Kv transmission system?If so what is the normal range of tap changing used?Is it OLTC or DETC? In such trfs tap changer will be a weak link in trfs and hence can we avoid tap changers in UHV system and get system voltage stability using tap changing in EHv system? What is the practice in countries where UHV is used,say US,Canada,Russia ,Brazil(?)
RE: Tap changing in 765 KV Power Transformers
http://www.condumex.com.mx/cdxinc/powertst/trans.pdf
for a tap changer at 230kV
http://www.imp-power.com/pr_oltc.html
for a tap changer at 66kV
http://www.selinc.com/techpprs/6136.pdf
etc. for more info
