Design Tables?
Design Tables?
I have successfully inserted design tables into part files to generate multiple configurations. In some files I deleted the design table afterwards, in some files I left the design table alone. What is considered the "best practice"? I would also like to make derived configurations of the configurations generated by the design table (same geometry, different part # & material).
This has been working without any issues in SW2001 - SW2003.
Now that I upgraded to SW2004 all my configurations are using the same dimensions.
Any ideas on how to salvage my files with their configurations and derived configurations?
RE: Design Tables?
If I never need the Design Table again, I delete them. For standard parts that have a bunch of configs, I save the design table externally, and delete it from the file, just in case. If i ever need to change the stuff in the DT, like the "matl" for instance, I change the external table, and then re-import the DT into the part to update all the configs.
Mr. Pickles
