need a high frequency power
I need a power source
output sine wave
frequency: 2450 MHz
Voltage: 10 kV
power: 50 W
I have no idea in it, anybody can give me some information in products or show me a way to design it.
Thanks in advance.
RE: need a high frequency power
I don't think you can get 10KV with 50 W in free
 space at 2.4GHz, but it may be possible inside of a cavity.
50W at 10KV would be 2 MOhm -- any piece of wire even
 only a .1 inch piece would have significantly less
impedance in free space .
Even if it is OK inside of a cavity, it has to have extremelly high Q. Perhaps superconductive ? Niobium
plated invar in liquid He ? If the frequency is critical,
it will take some experimentation to tune it...
Are you sure in your numbers? can't you get the required
effect somehow differently ? Is this for some nuclear physical experiment ?
<nbucska@pcperipherals.com>
Thank you very much. Yes, I am working in accelerator physics.
In our lab, another group is developing superconducting cavity, though this one is not here. I know little in cavity.
Since we have 500MHz and higher power level circuit, somebody write to me and want to buy one.
As I know, my friend here are planning to buy the cavity and superconducting system from laboraotries from German or japan. I can ask my collegues here directly.
