Digital distance measurement using wheel
I am trying to make a distance measuring device using a wheel (just like a digital odometer in a car). Can I find a chip with sensors(I am sure sensors will be attached to a wheel) that outputs distance in a digital format so that it can be stored in a memory? DigiRoller II Plus is a similar device but all I need is a circuit with output pins that outputs distance measured by a wheel (no LCDs or similar components attached attached). Does anyone know such circuit or chip?
RE: Digital distance measurement using wheel
I realize you do not want any displays so how to plan to read the distance from the IC pins? The output format can be binary or BCD. Depending on the distance of each pulse and the distance you plan on measuring, the digital output might be a little cumbersome to read depending on the number of bits you need. In any case, your project has been around for a long time and you should have no problems locating counter IC's (do a search on google or just go to some large IC mfg's sites and search for counter, maximm, analog devices, TI, linear technologies, etc)
How many ?
<nbucska@pcperipherals.com>
