Timing Belt Profiles
Hello Everyone,
Does anyone know of a resource where I can find the profiles and geometry of all the standard English and Metric timing belts?
Rich....
Rich....
Richard Nornhold, PE
nornrich@redrose.net
RE: Timing Belt Profiles
or Gates HTD Belts on the google search
enginge. The information should be in
Machineries Handbook as well.
Classic trapezoidal toothing. - A
The first ever developed type of synchronous belt. Can be used in older or hereditary constructions. It is not possible to achieve today's technical level, accuracy, minimum dimensions and price if used in new constructions.
Profile:
Dimensions: MXL, XL, L, H, XH, XXH (inches) T2.5, T5, T10 (mm)
Powers: up to 200HP; up to 10,000 rpm; up to 8,000ft/min
Rounded shape of the tooth. - B
Improved type of synchronous belt. Applicable in a wide range of powers and speeds.
Profile:
Dimensions: (HTD) 3M, 5M, 8M, 14M, 20M
Powers: up to 1350HP; up to 20,000 rpm; up to 16,000ft/min
Special rounded shape of tooth. - C
Other improvements in synchronous belts. These show higher specific transferred powers, higher accuracy and lower noise.
Profiles:
Dimensions: (GT, GT2, STD) 2M, 3M, 5M, 8M, 14M
Powers: up to 800HP; up to 20,000 rpm; up to 16,000ft/min
Derived and special types.
Obviously, the most important types derived from the most widespread basic types are:
Double-sided belts - transfer of power using either side of the belt.
Belts of final lengths - delivered in rolls (up to 60m), designed for rectilinear reversible motions or to create non-standard (great) lengths.
Catalogues of producers include other special types for various specific purposes.
mirekp
http://www.mitcalc.com
Mechanical calculations
