Derating Cables in Water
Hello.
Do cables that sit in water have to be derated?
The situation I am refering too, is where i have a submains cable that is installed underground in heavy duty conduit. The conduit is filled up with water completely and the water is not draining anywhere.
Should the cable current rating be derated?
Thank you.
Thank you.
RE: Derating Cables in Water
