MODEL TWIST DRILL
MODEL TWIST DRILL
Has anyone succesfully and accuratly modeled a twist drill or similar tooling , and , is it worth the effort. Currently using UG V18.
RE: MODEL TWIST DRILL
Caveat: You must use the advanced sweep so that your swept cut stays parallel to your helix axis throughout. Choose Insert/Free Form Feature/Swept. Consult the CAST help for questions about sweeping this way. Good luck!
Hope this helps.
Is this the methos that is to be used to model even multistart threads?? Or do we have anyother method.
Thanks in advance,
Karthik
I have modelled various twist drills and multistart reamers. If anyone is still interested I can post some useful hints/tips and shortcuts.
Simon C
