Aluminum fan blade failures
Just looking for general comments on a problem we are having with aluminum cast fan blades. Without getting into a lot of fan details, we've had 4 recent failures ( catastrophic) of the blades. Visual inspection of the blades looks like there are large cavities or pockets in the casting ( predominently where the blade meets the stub end where it is held on to the hub). Should the casting, irregardless of the type (grade) of aluminum be 'bubble free? or are bubbles inherent in casting aluminum? Would different grades be more prone to 'cavities' or bubbles? (The seller is only a supplier, who gets the blades from a foundry )
RE: Aluminum fan blade failures
Cory
As Cory stated, porosity is to be expected. It can be rated by radiographic analysis and metallurgical cross section.
You should also involve the fan manufacturer in determining the root cause of failure. Is it materials related, design related or operating related? Are you operating in a harmonic regime - in a corrosive atmosphere? Did the manufacturer receive substandard material?
You can tell your supplier about strength,enlogation,hardness.I think a experience foundry engineer can help you.And can tell you proper casting method.
