Air flow/pressure gradiant on flat perpendicular plane
I am looking for any information/references for the air flow or air pressure gradiant on a flat plane perpendicular to the movement of the air. I am not looking for anything really in-depth accounting for features on the wall, just for a plain flat wall. Any help you could give would be greatly appreciated as I have been unable to find anything on the web or books that we have to reference to. The wall(a/c unit) is set flat on a roof curb (and not considering minimal recess in the curb), I am assuming its a flat plane for this research. Also, I believe, although I could be wrong, that this is something similar to stagnation flow in fluid dynamics, but I have no experience with that other than a co-worker told me to look towards it for something similar.
It would actually look something like this:
|____|
____|___|__
with the recesses being very little compared to the unit itself. I believe they are in the neighborhood of 1-2" compared to the 8.5' height of the unit.
So, if anyone can either point me to, or post examples of gradiants, what that is actually called, and/or formulas for the gradiant and pressures I would really appreciate it.
Thanks for any help,
-Tyson
|____|
____|___|__
-Tyson
RE: Air flow/pressure gradiant on flat perpendicular plane
Are you looking for a drag force to design your mounting of this a/c unit, or for something more subtle that requires a pressure distribution?
STF
-Tyson
(1/2)*rho*V2 where rho is the density of air.
The pressure will drop off as you move outward to the sides on the windward face, but to design a mounting, applying stagnation pressure over the whole face does not necessarily overestimate the force enough for some margin of safety. Hoerner's book gives a drag coefficient of 1.05, so you actually get MORE drag force than a stag pressure X area of face. This may be due to all the turbulence at the back. Technically there's also a negative stag point on the back of any body, but turbulence confuses the matter.
Here's a hint: very rarely can CD get higher than 2, because a forward face with a positive stag point, and a back face with a negative stag point equal two areas offering the same resisting pressure.
That said, Hoerner DOES quote some drag figures that are higher than 2.0, so watch out.
Pages 4-3 and 4-4 should help you out the most.
Once the flow becomes oblique to the box, all bets are off. You might find there's a side force at some assymetrical angles.
STF
Again,
Thanks for the help,
-Tyson
