Dwg looking for a part
I have an assy dwg that is very slow to open and save. Whenever I open it, it can not find one of the parts in the assy and asks me if I want to find it. I find it then save it. This happens everytime I open the dwg, but never happens when opening the assy. Any suggestions?
thank you
thank you
RE: Dwg looking for a part
One longshot:
Do a "Save As" to make a copy of your drawing to a different name or directory, then "Save As" back to the original. Maybe this will "jiggle the handle" and get the references in the file to update properly.
Good luck!
thanks
-OR-
replace the assembly reference with the same assembly in SW Explorer.
