Visual Basic Scripting error
I'm working on a project with a WinCC 6.0 application which communicates on one side with a S7-300 and on the other side with a SQL Sever 2000.
The WinCC PLC communication works perfectly but I have some problems with the communication towards the SQL Server.
I'm trying to send some tekst (example G1 or H2 ect) from WinCC towards the SQL Server, I use in WinCC the datatype String (CStr) and I use the datatype Char 16 in the SQL Server.
I'm using Visual Basic Scripting. Each time I would like to send this data I recieve this error message of my VBS debugger
[Microsoft][ODBC SQL Server Driver][SQL Server]The name 'G3' is not permitted in this context. Only constants,expressions, or variables allowed here. Column names are not premitted
This is the VBS I wrote
Sub OnLButtonDown(Byval Item, Byval Flags, Byval x, Byval y)
Dim objConnection
Dim strConnectionString
Dim lngValue
Dim strSQL
Dim objCommand
strConnectionString = "Provider=MSDASQL;DSN=CLaSS_Production;UID=sa;PWD=siemens;database=CLaSS"
lngValue = HMIRuntime.Tags("Linenumber").Read
strSQL = "INSERT INTO BHI_baalhoek (linenumber) Values ( " & CStr(lngValue) & ");"
Set objConnection = CreateObject("ADODB.Connection")
objConnection.ConnectionString = strConnectionString
objConnection.Open
Set objCommand = CreateObject("ADODB.Command")
With objCommand
.ActiveConnection = objConnection
.CommandText = strSQL
End With
objCommand.Execute
Set objCommand = Nothing
objConnection.Close
Set objConnection = Nothing
MsgBox ("data Is Verzonden")
End Sub
Anyone who knows what I'm doing wrong
Dim objConnection
Dim lngValue
Dim strSQL
Dim objCommand
objConnection.Open
With objCommand
End With
objCommand.Execute
objConnection.Close
End Sub
