Storage tank design trends
I am working for a company that is operating in the petrochemicals and chemicals environment. I am responsible for specifying storage tanks (AST’s i.e API 620) for new plants. These tanks are typically between 10m and 30m in diameter. Also, some shop fabricated tanks. I am currently investigating trends in storage tank design and fabrication. Many of the tanks that we have been dealing with lately contain products with a high vapor pressure or that are hazardous substances.
I am trying to find out if there are any trends over the last couple of years in the fabrication details of storage tanks that are aimed at preventing potential spillages due to equipment failures. More specifically, I want to know if there is a trend towards full penetration bottom corner welds, and if there is a trend away from single lap welded bottoms to full penetration butt welded bottom plates. Does anyone have statistics on how often tank bottom lap welds tear and cause significant spillages, or is general corrosion the only cause for tank bottom leaks
RE: Storage tank design trends
We were losing S/S tank bottoms due to MIC and chloride indueced SSC. C/S tank bottoms were lost due MIC and general corrosion usually in slag pocket that slipped by the vacuum box. We lost one due the contents causing problems with hydrogen.
One word of caution is make sure you have the customers' current specifications. Tank specification are changing fast.
See www.ast-forum.com
MJC
