fam table elements
fam table elements
Hello, colleagues
I've stumbled upon the following problem:
1. There exists a family table
2. Fam. tab. instance name differs from its true name (by true name I understand its name in accordance with any standard - DIN for example)
3. I have an intention to use instance name in some report. For that purpose I've introduces a parameter "NAME" in generic.
Q: I want this parameter be different for every instance to reflect their true names, but it seems to be impossible. Can you suggest any alternate technique?
Thank you.
Thank you.
RE: fam table elements
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
Suppose names of the instances cantain dots or some other taboo symbols. What should I do in that case?
im4cad
