LIST OF HIGH PRESSURE PUMPS MANUFACTURES
I would like to have list and email addresses of High pressure Pump manufactures.These pumps are being used on cranes, and for other industrial applications like on machines .The pressure should be 350 bar or above 350 bar.These  pumps can be Gear type or Piston type for Hydraulic Fluid as medium of flow.
Thanking you.
Rakesh Sharma
RE: LIST OF HIGH PRESSURE PUMPS MANUFACTURES
Hi high pressure pump,
Check any of the search sites (yahoo,msn ) by putting (hydraulic pumps)..a good equipment site is (www.askache.com)
Good luck,
Whylie
Suggest that you post this on www.pump-zone.com
They have an active bulletin board with many people who are anxious to jump on an opportunity like yours....
Suggest that you state more information about the application.
MJC
Check out this site.
http://www.nfpa.com/
Some of the major manufacturers are:
Sauer-Danfoss
Rexroth-Bosch
Parker
Eaton-Vickers
Just to name a few.
Try CAT
