Heat Shrinking
Heat Shrinking
We are welding 5/16" mild steel plate on the top of a helideck to the top of W12x 16 beams with the spacing in between the beams are approximately 32". The fillet weld used is a 3/16" ("according to spec.") and we are using GMAW-S to minimise heat input. We are experiencing the sheeting sagging up to 3/8" in between the beams.
What can be done to minimise this as well as fix these sagging areas?
Heat shrinkage is allowed but how is it done?
RE: Heat Shrinking
Bracing can be used but its needs to be engineered.
Is the 32" flange to flange or web to web?
RE: Heat Shrinking
Any pointers on Heat Shrinking?
RE: Heat Shrinking
My first recommendation (to save me a lot of typing) is to get your hands on a copy of the Lincoln Procedure Handbook of Arc Welding. This publication is inexpensive (<$30) and will give you many guidelines on how to avoid the distortion for future welds. I think this book can be ordered directly from Lincoln, but most welding suppliers keep them in stock. Section 3 has many procedures on how to avoid the distortion before it becomes a problem.
Heat the area that is sagging (from the side that is concave) to about 1100 degrees F, weed burners work better than acetylene w/rosebuds by the way. Apply cool water at this location gradually, not all at once. We used this procedure a few weeks ago for a similar problem where plate was warping between channels at a location where we needed a relatively flat surface. Worked like a charm.
RE: Heat Shrinking
Here is Lincoln website to order from.
https://ssl.lincolnelectric.com/foundation/
