Electrical Wiring VW Alternator
I just bought a VW Vanagon and found out that the wirirng comming from the altrenator "Bosch" are disconected. It has two red wires comming from the voltage regulator that is in the alternator. One wire is bigger than the other. I believe that one goes to the hot side of the battery but the other I have no idea were does it go?
Thanks.
bmail
Thanks.
bmail
RE: Electrical Wiring VW Alternator
As for the wires, the larger one goes on the terminal marked "Bat" and is most likely the alternator output to battery.
As for the other, look for a terminal marked "Ign" (Ignition).
Good luck.
