URGENT - sizing of transistors for layout!!!!
On the process I am working on the minimum gate-length is
0.6um. I need a transistor of dimension 60/0.2.
I am thinking that if I stack three 60/0.6 in parallel I
will get an equivalent transitor of 180/0.6 or 60/0.2. Is
this a valid assumption??
Thanks a million.
Dominic
RE: URGENT - sizing of transistors for layout!!!!
Your assumption is incorrect. Why are you using a 0.2u gate length device on a 0.6u process?
