Connection diagrams for 1phase 240volt capacitor start electric motors
Require connection diagram for twin capacitor single phase 240 volt 370watt 1380rpm Asea IEC34 IP54 Electric motor
RE: Connection diagrams for 1phase 240volt capacitor start electric motors
http://www.lions.odu.edu/~jhackwor/365/365-07.pdf
Just look at the capacitor start motor connection in the diagram (there is other stuff shown, which you can ignore)
There are 3 wires on my motor, red, white and blue. The red and blue are connected to a 4 terminal capacitor. The other 2 terminals on the capacitor go to a control board. I am trying to salvage a motor from a garage door opener.
http://www.tpub.com/utilities/147.htm
http://myweb.tiscali.co.uk/montecarlo/marine-electrical/Ch17.htm
etc. for more info
What do you plan to do with that motor, since it has a very SHORT duty cycle!
White is common, red & blue are forward & reverse.
I plan to use the motor on a small lathe and it will run for short periods of time at heavy loads (which still should not tax a 1/2 horse motor) and longer periods say 15 minutes with little or no load.
Will this be a problem?
Best regards,
Mark Empson
http://www.lmphotonics.com
If you look on the ABB website:
http://search.abb.com/library/ABBLibrary.asp?DocumentID=B5.0207&LanguageCode=en&DocumentPartID=&Action=Launch
- it's quite a large file, single phase motors are covered in section 7 (p191), there are some diagrams which may help, or they may not.
The load is not the problem for that motor. It's the time and lack of cooling!
Typically, that motor has no fan on it to cool it so you will need to force air over it constantly!
Also, it is probably a permanent split capacitor motor with a capacitor that WILL explode if you run it for 15 minutes!
I think you would do best to purchase a standard Continuous Duty Capacitor Start motor for your application, since the motor you have was never designed to do the job you describe!
Will heed the advice and get an appropriate motor.
thanks again.
