Panel meter DC power supply ratings.
I've been trying to find a simple single phase digital voltage display to indicate LTC voltage. I would like to power the device from a substation DC supply. I keep finding devices, from manufacturers of utility grade equipment, rated for nominal VDC +/- 10%. This tolerance is below normal float voltages, and way below equilization voltages. What are their intended applications? Any standards that apply? And who knows of a good one with +/- 20% or better tolerance with settable high and low limit contacts?
RE: Panel meter DC power supply ratings.
Bitronics/Alstom mentions that their watt/var meters are available with optional ‘single supply that operates from 24, 48, 125 or 250V dc source or 115V ac service’ Perhaps the same power-supply range is available for their 1ø single-function products.
Volt/ammeters are indexed at www.esca.com/content.cfm?content_ID=1880
What a terrible web site. You'd think they'd have the new one more complete before tearing down the old one. From their paper catalog, anyway, it doesn't look like they have what I need. It is interesting to note that their universal PS for nominal DC voltages up to 250 specs out up to 280. If you have a 250V battery I guess you float it low and never equalize.
Steve, I haven’t used any of their stuff since the "merger" but it seemed to be well engineered and fairly rugged. Hard to tell if Alstom changed the way they do business, but agreed the web site is close to worthless. And the (C37.90) 280-volt rating would make more sense.
(you might have to register to see this page
I've pressed a couple of the +/- 10% manufucurers, and they claim their 48VDC units will work fine at equilization voltages of 56 and higher. Why didn't they say so in the first place?
