Facultative Lagoon Design
I am in the process of formulating the process design for a 5 MGD facultaive lagoon WWTP with pond depths of 7'. BOD and SS loadings are quite high: 26,000 #/day and 29,800 #/day respectively primarily due to milk processing wastes. Client does not want to supplement natural aeration/photosynthesis process with mechanical aeration in the winter (quite windy location). The average winter air temperture is 47.3 F. The calculated BOD loading to determine surface area needed, depending on the reference, varies between 17.4 #/ac-day to 168 #/ac-day. The references are somewhat dated. With my reserch to date, 40#/acre-day BOD loading rate seems reasonable. Current loading 56#/acre-day but at times D.O. maintenance is problematic. Any feedback on best references and/or recommended loadings?
RE: Facultative Lagoon Design
Good luck
They will give a good information about this topic.
