Billing For Electricity Used
Is it possible to calculate the exact cost for electricity used over the past 18 mths in a comms room. The supply is metered with a Socomec Diris AP type meter, which does not have the option of kWh. The units that can be read off the meter are kW, kVAR, kVA, V, Hz, A and the hours run.
If its is not possible to get an exact cost can this be estimated. Any help would be greatly appreciated.
RE: Billing For Electricity Used
It is remotely possible that an accessory module that will provide a watthour KYZ-pulse output could be obtained. Connect it to a counter and log a month's worth of usage, and vaguely estimate the prior interval. This assumes that the metering devices and associated instrument transformers are suitably accurate for revenue-transfer purposes.
With digitally-displayed information, it is critical not to confuse resolution with accuracy.
I was hoping that I could calculate the kilowatts per day, from which I could then get kWh. The rest of the facility has kWh meters and using the cost per kWh from the suppliers bill the tenant bills are calculated.
