150-300 Forged Flange fittings weld stress
In reference to my unanswered threads, any proffessional opinions out there are very welcome. I am assessing the weld stress/strength when subjecting the fittings to a tensile force of 17 tons. The fittings are SOW type joints with double fillet weld. The welds are magnetic particle inspected. ASME VIII in section UW-12 suggests joint efficiency of .55 when no radiographic examination has been performed for this joint type.
Question: 1)What joint efficiency should I use for MPI?
2)Is UW section of ASME VIII where I should be looking for this weld design/stress/joint type assessment?
3) Are these joint types catagory C according to ASME VIII.
4)Section UW-18 fillet weld page 128 (d) of ASME VIII equation Allowable load=weldarea*yeildstress of weldbasematerial*E(efficiency) be used for this application tension test.
Any help comments thank you.
RE: 150-300 Forged Flange fittings weld stress
ASME: Always-Sometimes-Maybe-Except
PED: Pain Every Day
Should I just assume joint efficiency of 1 for MPI method??
