model space and layout s
Hey everyone,
Just a simple question that i cant figure out! When you create something in model space on the model tab, how do i get whatever is in the model tab to NOT show up on the layouts i create on the same drawing. I want to use view ports to show sections of the model drawings but i cant seem how to figure out how to hide the entire model drawing so it doesnt overlap on the other layout tabs.
Thanks!
Thanks!
RE: model space and layout s
You should read in help of autocad command mview
I will show you one way I usually
1.You should create a new viewport with new layer( only use for define viewport) , remove the old in layout
2. use mspace command , you are in haft model and paper space .
3. use zoom command / scale type the scale you want
or you use vport toolbar choose the scale you want or custom.
4. Use pan adjust location . And adjust size of frame . If you don't want to show border viewport , just turn it off.
Hope it help you
Cad123
Flores
Create new viewports in the layout and notice that it again repeats the objects in the modelspace- not a problem.
Select any of the viewports u just created in the layout by double-clicking inside the viewport. this gives u the opportunity to set the object to whatever scale or view u want.
Repeat this for the other views u need.
Hope this helps.
greg
