Fake dimensions
Fake dimensions
I am adding a note to a feature. The note involves two parallel surfaces so I used a horizontal dimension. Then I edited the number to input the text I need (erased the dimension value and typed in my text). However, this creates a "fake dimension" which is not a good idea. Any thoughts about how to use the horizontal dimension (getting leader lines and arrows automatically) to add a note without making it fake? I could draw them in but UG is supposed to make life easier, right? Thanks.
RE: Fake dimensions
-Dave
http://www.moslerauto.com
RE: Fake dimensions
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
RE: Fake dimensions
RE: Fake dimensions
Use the Annotation preferences to set the text size of your dimension to .0001 and the dimension to not display decimals.
Create your Fake Dim as an annotation and place it with the associative offset character option and pick the dimension as the reference. A X=0 Y=0 offset to the middle of the reference dimension should be good.
IF you do this you can move the real dimension with the edit origin tool and the fake text will follow it.
Michael
RE: Fake dimensions
Is it possible to create fake dimensions in NX2?
Dave
RE: Fake dimensions
Yes, you can still create fake dimensions.
Simply Edit -> Text. A warning box will appear, and you will have to accept it and click again in your annotation window to continue typing your new text.
RE: Fake dimensions
how can i put a dimension for a threaded hole?
if i select the thread circle, it offers diameter symbol instead of "M"
does UG has a normal option for this?
kukelyk
RE: Fake dimensions
-Dave
Everything should be designed as simple as possible, but not simpler.
