Flange Bearing
Flange Bearing
Flange Bearing
Greetings.
I posted this message in the Bearings Forum...but didn't look like much activiy goes on there...is it allowed/rude to post the same message in more than one forum ??
Anyhow,  I am looking for a flange bearing which has a housing of ductile cast iron or steel with a bore greater than 3.5" diameter.
Any help would be greatly appreciated.
Thanks !
RE: Flange Bearing
I know Browning makes a FB900 series (and others)made of ductile iron with 3-1/2", 3-15/16", and 4" bore sizes.  QM offers both steel and ductile iron in the bore range you're after.  Try Browning @ www.emerson-ept.com or QM @   www.qmbearing.com.
RE: Flange Bearing
See my reply on the original post!
Lester Milton
Telford, Shropshire, UK
