Ductile Cast Iron Housing for Flange Bearing
Greetings.
I am looking around for a flange bearing with a housing which is either steel or ductile cast iron. I need the bore of the bearing to be 3.75" to 4.25".
The best I could find was a Browning flange bearing with a bore of 3.5". There are many others that I found with larger bores but not with a ductile cast iron.
Any help would be greatly appreciated.
Thanks !
Thanks !
RE: Ductile Cast Iron Housing for Flange Bearing
But do you know of the 722 Series flanged housings? These have a small double row ball or even a small spherical roller bearing in. Sometimes useful in certain applications as you can seal them a damn site better than standard MSF housings?
Ask your SKF dealer for 722522 housing information.
Lester Milton
Telford, Shropshire, UK
