Distance of bolt to OD on reverse flange
I need to check a reverse flange with stud-bolts.
OD flange 813 mm
Stud Bolts M39 OD 39 mm
Bolt circumference diameter 749.3 mm
Distance from the OD to bolt 12.35 mm
I does not found any code ( ASME, BS, Eurocode ) that
give me a rule to define the minimum distance between
the bolt and the OD diameter.
The problem is the same of a loose flange with bolts nearest to inner diameter.
Many thanks in advance for Your help.
Best regards
OD flange 813 mm
Best regards
RE: Distance of bolt to OD on reverse flange
